Read more
Wishes
Label thickness of core and finish of slab
Erwin Edel
I would like to label the thickness of the core and the finish of a slab.
Currently I am typing these into simple text fields, meaning if I change the composite of the slab, I need to remember to adjust these text fields manually.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
2 REPLIES 2
DGSketcher
Legend
I am hoping we might see a solution to that issue come from this thread...
https://community.Graphisoft.com/t5/Design-forum/Component-Level-Design-Workflows-Conversation-amp-f...
Might be worth adding your opinion if you haven't already.
Thank you, I will see if I can get around to it.
www.leloup.nl
Windows 10 Pro
