2024 Technology Preview Program
Wishes
Let Grasshopper have access to project libraries
derekjackson
When working with Objects in Grasshopper, if you want to create an object then you need to explicitly pick the object beforehand.
Allowing Grasshopper to parse the library to be able to search for objects on the fly would allow for much more efficient scripts, as it could decide which object to place based on other variables within the script.
Yes, Favourites are an option, but when dealing with lists of hundreds of objects for a project, scripting these individually results in scripts that are too heavy to run.
0 REPLIES 0
