Read more
Wishes
MVO Override to make Windows/Doors solid recesses.
It would be great if there were a model view option override to change windows and doors to simple recessed solid opening to aid with 3D printing.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.0
macOS Sonoma (14.4.1)
5 REPLIES 5
Schematic turns them into a single plane.
Does this help?
Or 'Simplified' will have a simple frame.
Lingwisyer
Guru
No way for you to set your printing software to do like a 20% infill to voids and cantilevers?
You can but that is generally for support whilst printing and is then removed especially for cantilevers. I’d almost like the windows and door openings to be replaced with a deep niche so you just get the simplified opening without having to change the entire model every time I want to print it.
Lee Hankins
Lingwisyer
Guru
Ah, so you are wanting an indicative opening without there being an actual penetration.
That’s right yes. It would be nice to be able to almost print directly from the model without acing to do lots of preparatory work.
Lee Hankins
