Wishes
Make folders available for Zone Categories too
ML_Arco
Folders are now available for many attribute types, but not for Zone Categories - why not?
Would be great to be able to separate different category types to their own subfolders.
The uses for zones are quite varied, at least where we operate (Finland):
  • different Gross and Floor area categories, needed for client and official building permit area calculations (about a dozen categories)
  • Then there's categories for multi-room area entities of one specific owner or tenant (apartments, office suites, etc, ca. 50 categories)
  • And finally, singular rooms need their own categories, defined by the intended use and now mandated to be submitted via ifc models when applying for a building permit. There's over 200 of these.
Cramming all of these in one endless list just doesn't make sense. Folders would solve this.
Mikko Lahti - Helsinki, Finland
BIM specialist
Archicad user since 2004
2 REPLIES 2
runxel
Legend
Totally agreeing that folders should be everywhere, even if it's just for the sake of unifying the UX.
But just one question: What is the reason you actually have so many categories? Since we have classifications and properties I never had the need for that anymore. Just curious why you have all of them in the first place.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
The room zone names and categories will be mandatory by law beginning next year as we move into a system where building permit is applied with IFC models and the IFCs need to incorporate precisely defined IFC property data that is then machine-read into governmental registers.
Using Archicad properties for setting the required specific category etc for zones is an option, but the problem of having a very long dropdown list without subsets/folders would remain even with that approach.
BIM specialist
Learn and get certified!
