2024 Technology Preview Program
Wishes
SOLVED!
Modifying windows and doors
Strawbale23
Is it not possible to select a window that has already been carefully created and be able to change the type of window without having to start all over again?
I want to be able to modify an opening for a a different type door and window, without needing to rebuild it,   shutters, reveal, casing materials etc.
AC26
https://www.zendsign.fr/
2 ACCEPTED SOLUTIONS
Solution
You can pick up the current window/door settings using the eyedrop (alt+click), then open the settings panel for the window, and on the left hand side scroll select the new window type you want to use but do not click it - instead, inject the settings into the picture (ctrl+alt+click). It will keep all settings, but change the window type to the selected one.
Jeliszej Korcsák
Architect, BIM Manager | ArchiCAD 27 HUN Build 4030 on Windows 10 Pro 22H2
Solution
Eduardo Rolon
  • You can use the eyedropper to pick the original window settings
  • Open the Window and press they shortcut for the pipette (CMD+OPT) and click on the icon for the window BEFORE selecting it.
  • AC will copy as many settings as are common to the new window.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
10 REPLIES 10
Solution
Jeliszej Korcsák
Solution
Eduardo Rolon
AC27 US/INT -> AC08
another Moderator
Thank you!
There should be a right click menu option to "Modify Window", which does this.
AC26
Otavio Augusto
Certified Trainer
Hello @Strawbale23, yes, you can do it, by pressing ALT on the already created window type in the definitions, and CTRL+ALT in another window type, that it will carry the chosen options.
bucha-michael
I've tried everything, but there's no way I can turn on the eyedrop in Archicad 26 in Windows with the window settings open. Is this feature only available in Archicad for macOS?
You can inject your settings in the window settings dialogue, but you have to pickup the settings from the window in the plan.
bucha-michael
Oh, I found where the problem was... The eyedrop shows up with CTRL+ALT only in the window settings dialogue only when I have on the left side the base directory with basic windows. But I have opened on the left side my favourite windows directory by default - where the eyedrop doesn't show up and the settings can't be overwritten. Thanks for discovering the new feature!
@bucha-michael wrote:
The eyedrop shows up with CTRL+ALT only in the window settings dialogue ...
Just to clarify, that is the inject properties (syringe) icon you are seeing.
The pick up settings (eye dropper or pipette) is not available in the window/door settings.
