Read more
Wishes
Multi-storey opening
ovt
Multi-storey opening as an independent object, that perforates everything by default (between given heights).
4 REPLIES 4
4dProof
the opening tool can punch through multiple slabs on multiple stories. Or are you thinking like a window/door that can span platform framed walls? I use a window in one wall and an opening (or window set to empty opening) in the other.
ovt
Thank you. I know the opening can punch multiple slabs, but adding them individually is kind of slow.
VLBE
Hi, could you maybe share the process of doing this multi-story opening running vertically through multiple slabs please?
Maybe one of these videos will help.
https://www.youtube.com/@Archicad/search?query=opening
