Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Offset modifier inside Columns & Beams
runxel
Let us have an offset modifier inside the columns and beams tool.
This offset would control the distance between the complex profile's 0,0 and the construction line.
Mostly AC 26 on Mac | Author of SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Could you post a screenshot that would illustrate this and show the results achieved by this wish? It would probably be easier for users to decide if they support the wish or not.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Geof Gainer
It would also be nice to be able to control the plan view appearance of each segment. For example a column comprised of a concrete footing / concrete stem / wood post would allow you to dash the footing to show it's below grade, give a thin line to the stem, and a thick cut line to the post. Or better if those lines were predetermined by the story they occurred on, as in Floor Plan Display.
AC fan since v 7. Currently on AC 26 Build 5003 USA FULL Apple Silicon,. 2022 Mac Studio, 32G ram. OS X 12.6.2
