2024 Technology Preview Program
Wishes
SOLVED!
Offseting Single line
moreha
If we have a single line not a Polyline or Circle etc, how can we make an offset from that single line using offset tool?
I know that it's possible to draw a new line using offset constraint but would like to know if it's possible to make an offset of a single line through the Offset Tool itself! Because as far as I know, we can make a new offset by dragging polylines, circles, arcs, etc using the pet-pallet or using the offset tool!
1 ACCEPTED SOLUTION
Solution
DGSketcher
Legend
If you have snap guides turned on AC will display with a 90 degree symbol if you are moving the new point a perpendicular distance from the original. Hope that helps.
18 REPLIES 18
DGSketcher
Legend
Simply move or drag a copy. You don't need an offset tool for a single line. The point of offset tools is best demonstrated with the poly line tool where the offset will change the vertex points to suit the new geometry. The relation of the vertex points of a displaced line remain constant to each other.
Thank you for reply, but when the single line has an oblique angle not orthogonal constraint, the offset distance perpendicular to the original line would be important in most cases.
Best wishes!
Solution
DGSketcher
Legend
snow
You've got the SSA?
...if, you can use this addon:
archicad versions 8-27 | mac os 13 | win 10
I do not have this additional tool set!
@snow wrote:
You've got the SSA?
 That is a country-specific add-on limited to your market.
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.7, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
snow
Sorry, I didn't know that.
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
You are welcome and thanks again for your kind attention
