2024 Technology Preview Program
Wishes
Opening in beams
agroni
A nice option would be to make an object for cut openings in beams, as we have for walls.
Currently to make an opening in a beam, we must use the integrated option of the beam. Sadly, this produces a limited element in the aspect:
graphical representation: the opening symbol is managed by the Modellview which turns off the opening when the option “only contours” is applied. It is strange that the opening symbol is connected to the axis symbol of the beam!
annotation: you cannot describe the opening by using a label tool which ideally would consist of a height x width (just opening) and additionally the height of the opening in relation to my project origin.
It would be cool if GS would give more importance to the cut openings also in beams, since they are a big part of the planning and construction.
In the image below I have presented the future possibility for the beams
The BIMster @ AllesWirdGut
Currently: Archicad 26
User since Archicad 6.5 (2001)
0 REPLIES 0
