Read more
Wishes
Orientation change of walls and beams relative to guidelines should be more streamlined.
Ro-Ra
Just an ease-of-use suggestion. If the user changes the guide line location within a beam, the beam doesn't move (good!). On the other hand, the user cannot change the location of the guide line location within a wall without moving the wall.
It would be nice to be able to do both for both types of objects:
- Flip orientation (guideline location stays the same, object is moved)
- Change guideline orientation (doesn't affect position of object, guideline location stays the same)
It might be worth considering implementing this ease-of-use feature for slabs, stairs, roofs, and other objects which use guide lines/planes.
1 REPLY 1
Are you sure?
Reference line stays put and the beam moves left/right/up/down when you change the anchor point.
Beam moves left/right if you adjust the reference offset value.
The same with walls when you flip walls on the reference line - the wall moves and the reference line stays put.
What version of Archicad are you using?
I think there was a time when the beam didn't move, but now beams, columns and walls all move around the reference line (which stays in the same spot) for consistency.
There is a command to modify wall reference line while keeping the wall in place.
