Read more
Wishes
Place Mesh from Surveyors Data - Survey Point alignment option missing
Miha_M
I often use the Place Mesh from Surveyors Data function to generate the site model. Sometimes I get all initial Data from a Survey plan. Sometimes I need to import .xyz data from another source (mostly Lidar converted data in CloudCompare).
The "Place Mesh from Surveyors Data" is missing the option for mesh generation aligned to the before set Survey Point.
There are workarounds, but such a magnificent software, which is sadly on a subscription conversion transition, should have the Survey Point functionality integrated in every aspect.
| Archicad 4.55 - 27
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
0 REPLIES 0
