I use a chin that can lift an object, but since it is not square in shape, I think I can avoid double work if I can use a profile.
There is something I don't understand while looking at the cooktop built-in. If you are removing and installing the top of a kitchen cabinet, the backsplash should be the same setting, but what I found seemed to be that only the height could be set.
Or shouldn't you be able to remove the top from the cooktop?
If I can't find it, I would really appreciate it if you could explain how to install the cooktop on the cabinet.
Also, I wish I could use the same profile as the cabinet backsplash for the cooktop backsplash.
AC27 on window 11
