Read more
Wishes
Prevent BIMcloud Libraries Updating when changing Location
It would be great if the process of checking for BIMcloud Library Updates was changed so that it didn't think every time you change local network that all of the downloaded BIMcloud Libraries need to be updated. Every time I switch from working on the same model with the same libraries between working at home and in the office all of the libraries seems to be re-downloaded and updated when it isn't necessary and delays the start up process.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.0
macOS Sonoma (14.4.1)
0 REPLIES 0
