Wishes
Publishing Sets button in the Pop-up Navigator
Pato99
Please add the Publishing Sets button to the Pop-up Navigator.
Another thing that almost got finished.
When they rolled out this feature I was so pumped! but then I asked, where is the publishing set? and the reply was "It's not used often enough".
Again, broken record, coming from a 400+ Per year plan background, I'm opening the publishing set many times daily. The publishing set tab in the Organizer has more complexity I understand, so I can see why they avoided the task. If they could just add a simplified version, that'd be nice.
I don't need all the bells and whistles or publish button, just the views. Thanks.
Praise to the almighty GS development team. #WeAreNotWorthy #Roadmap #VotingSystem
Versions 10 to 27
Metabox Prime-X P775DM2-G (Clevo),
GTX 1060 6GB GDDR5 VRAM - G-Sync,
i7-6700K (8M Cache up to 4.2 GHz),
32GB DDR4 2133MHZ,
512GB SATA 3 M.2 SSD,
Win 11 64
  • UI
0 REPLIES 0
