Read more
Wishes
Select through surface with sub 100% transmittance
This is ultimately about a better Element Visibility Control but as long as that isn't in place we have to do with what we got.
A surface with 100% transmittance acts as a wireframe and which is useful when modelling as it allow you to select through certain elements while keeping them visible as reference. Often you don't wan't a complete wireframe but rather a x-ray/ghosted effect which is achieved by decreasing the transmittance. However, doing so takes away the ability to select through the element.
Either any transmittance at all should enable select through or it should be able to set a threshold below 100%.
0 REPLIES 0
