2024 Technology Preview Program
Wishes
Shedule: how to get 3D views of object without shaded, RGB colors, but original surface colors?
MG
In shcedules, i`m listing doors, windows and objects, with 3D front view and 3D back view added. The doors and windows appear with the original surface color of the used surface, while the objects appear in varios RGB colors, I guess with form shadows. I can`t apply a graphical override as I have objects with more than one surfice.
Whats more, saving a pmk and exploding the schedule in worksheet doesn`t make it easier, as I can`t find&select rgb color fills to manually set the white (gray because shaded) to white.
Any possibility that I have control over the 3D engine of the shedule, or something like that?
(shreenshot: first 2 door/window, last 2 objects)
Thank you,
László
Archicad 24
1 REPLY 1
This is just a wild guess but try to set a Section or Elevation with the desired display settings for uncut surfaces, then go to the Section or Eelevation so elements are generated with those settings, then, while in the Section or Elevation, generate the Schedule, and see if that changes how objects are displayed in the Schedule.
