Wishes
Shell-Loft
An easy way to bridge multiple morph slices and produce complex geometry.
For us this was needed when working on traditional rural houses which had asymmetrical and uneven barrel vaults. which made a huge difference in terms of clear heights. Faking it with a perfect barrel vault was not an option
1 REPLY 1
Podolsky
Ace
You can achieve such a result using shell tool. It's specially designed for double curve surfaces.
Later you can convert your shell into morph - if yo really need that it would be modelled from morph.
