2023-07-21 04:10 PM
Is there a setting to add more show on stories options? Reason I ask is because when I use all relevant stories, then the floor plan display for symbolic is greyed out and I'm left with all the other options. Show on all stories works sometimes, but not always. My current work around is to put them in the middle level and have it show down, home and up. Would be nice to add Home, up 1 and up 2. From main floor to 2nd floor and also show on roof framing plan with symbolic display.
2023-07-21 04:23 PM
The "Custom" option which appears in some tools should be consistent throughout the whole AC storey display workflow. This has been a regular request over many years.
2023-07-21 07:59 PM
Temporary hiding for elements will be a good solution for this situation as you can only hide undesired elements without hiding layers and save this as a design option so you can document & schedule the view based on this.
2023-07-22 03:17 PM
Dang, I thought I saw the settings for that somewhere at one point and couldn't find it again, but I guess I must have been imagining it.
2023-07-24 03:26 AM
There is a listing regarding setting consistency on the Road Map.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Self-taught, bend it till it breaks | Creating a Thread |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
