Read more
Wishes
Site mesh gradient tool between mesh points
AndrewR
Often Designers or Architects Practices initially set levels on a site subject to approval of an engineer at early design stages. Could we please have an arrow similar to a dimension tool that indicates the fall between two areas or points on a mesh (i.e  noted as 1 in 60, 1 in 40 or 1 in 35 etc)? Could we also have a tool that from a fixed level point over a fixed distance (ie a box highlighted zone) create in that are say a fall 1 in 60 or 1 in 40 etc. Often an engineer will comment on levels and will introduce an area of an required fall (for example a HGV spin at 1 in 100). They would then be happy with the levels. Therefore a tool assisting in creating falls and quickly indicating falls on a mesh would be useful.
3 REPLIES 3
Benjamin Dani
Hello,
Thank you for sharing your idea!
I'm glad to say that we took notice and we have added this wish into our Wish list database.
(For future reference, you can refer to it as IDEA-12243)
I hope we see this get implemented in the future.
Have a great day!
Best regards,
Dani Benjamin
Technical Support Engineer
Scraptrash
(is this the way we vote on idea?)
MacBook Pro (16 inch, 2021) Apple M1 Max 64GB macOS Monterey Archicad 26 MBP trackpad Logitech Master MX3
@Scraptrash wrote:
+1
No, press the LIKE button on the original post.
