2022-09-11 10:02 AM
I simply would like to put a skylight in my roof like this....
Using the roof tool I put the composite roof on top of these beams and then added a layer of 1x6 timber between the metal sheeting up top.
Underneath I built a frame for the skylight.
The skylight sits directly on the metal sheeting on the top most roof layer shown in the first image. I want the skylight to go through both layers of the roof...Any ideas how to achieve this?
Solved! Go to Solution.
2022-09-11 05:07 PM
If we ever get the opening tool to work with roofs this should be easy.
For 3D purposes you could form a Morph and subtract it from the elements you want to remove using SEO. The Morph needs to be assigned a strong Building Material with a high Intersection Priority Value. Place the morph on a layer that will normally be hidden with its own unique Intersection Priority. Unfortunately SEOs won't show in 2D plans.
Alternatively you may be able to create a hole in roof if you are using roof plane elements to assist.
2022-09-12 10:55 AM
The simplest solution with the current build-up is creating a hole, as @DGSketcher suggested.
Alternatively, you could add the internal timber sheeting to the composite build-up so the rooflight will register the roof as a whole. It will likely need to have a separate eaves detail.
2022-09-12 07:06 PM
What I ended up doing is redefining my composite roof, I just added air space between the layers I wanted to have the timber. Originally I drew to roofing materials on top of each other with timber in between. That allowed me to use the skylight tool so that I could place a skylight that went through the entire roof...
2022-10-16 09:55 PM
I ended up having to manipulate the top-most layer so laying my skylight for some reason only could cut through the bottom composite roof and not the topmost metal roofing. I watched the "how to cut a hole in a complex roof" video and basically used the roof tool again, to make the actual hole the size I needed.
