Wishes
Slab obstructing Door
architect
The wall subtracts/operates on the slab:
But when the section cuts through the door, the slab no longer is subtracted, and the door is hidden partially:
Any way, besides adding an additional composite and pulling it back, to get this to show right?
2 REPLIES 2
Check in 3D that the wall is indeed cutting away the slab.
It may just be a display order of the wall in section that makes it look like it is in front and appears to cut the slab.
I see this presentation is correct as when you cut through the wall away from the door you’ll see the inside (left) slab finish stops at the edge of the wall finish.
But when you cut through the wall penetrating the door you’ll see the inside (left) slab finish extending under the door otherwise you won’t be able to open it if applied as in this wished presentation below.
AC 27 INT 5003/WIN 11
Learn and get certified!
