Read more
Wishes
Stair display on RCP, How does it work?
4hotshoes
The Stair tool has a RCP display mode with settings. But it is un clear to me how to make the stair know it needs to display as on a RCP vs the floor plan. How do I utilize the RCP display feature of stairs?
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
2 REPLIES 2
Gerry Leonor
2 ways to control how a stair looks is:
  • Model View Options
  • or it's own individual setting. you'll have to un-check the box that says "by Model View Options". unchecking it overwrites the MVOs & uses the settings for each stair element.
Most of my floor-to-floor spanning stairs are associated to MVO.
whilst low-height stairs (think fire escape stairs that are only around 500mm high) are not MVO associated (unchecked MVO box).
I would still have a specific MVO for my RCP drawings & ensure that the stair setting is set to RCP, which, in this case, is a pretty simplified  (for a concrete stair at least)
AC25 | Win10 | 64 bit | 16Gb RAM |Intel i7 8700 @ 3.20Ghz
come join our unofficial Discord server
https://discord.gg/XGHjyvutt8
Thank you Gerry. I figured that it was in the MVO, but I did not notice the pull-down selector. If it had been radio buttons, it would have been more obvious.
Todd Oeftger
