Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Symbolic view for complex profile walls
Complex profile walls can have many fills stacked above one another or even varying thicknesses to the wall at different heights - unlike a standard composite wall.
However in plan we don't have a "symbolic" floor plan display option.
We have to use the 'Projected' or 'Cut only' displays, which means we must rely on the actual 'Floor Plan Cut Plane' height to display those walls correctly.
This creates a problem when you want to display different heights of different walls or you have other elements that rely on the FPCP height.
Obviously because of the many varied fills and thicknesses, we would then need a way to nominate the default cutting plane height in the complex profile settings so we can get the correct (or desired) cut view of the complex profile.
This nominated height would be used as the 'Symbolic' cut of the wall.
So my wish is for a 'Symbolic' floor plan display view for complex profile walls.
6 REPLIES 6
NOW
event a simple half height floor. ( between Home Floor & Upper Floor ). that kind of floor editing for user is nitemare ......
3D Floor Cut is Perfect.
BUT 3D Floor Cut is USELESS....
IT LOCK ALL THE FLOOR PLAN FUNCTION..... user just View Only
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Barry,
Thanks for sharing the wish and creating the pool!
I'm happy to say that this is a known wish in our database (please refer to it as #7211). I hope that our Product Management team will consider adopting this one in the future!
Thank you once again, and have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Thanks Minh.
I will keep an eye out for it.
Hello Minh, any news about this?
thanks
Archicad 25 SPA v6000
i9 9900K/32 Gb DDR4/1TB SSD/10GBPS Lan/Windows 10 PRO
Minh won't be able to tell us anything about this, as he no longer works at Graphisoft.
All we can do is hope that it is indeed something that will be considered.
Thanks Barry
