2024 Technology Preview Program
Wishes
True Weight
ares997
It would be nice if the "show true weight" could be connected to a slider such that you could exaggerate the weight of the line work. Sometimes even when the true weight is shown it doesn't necessarily show up as heavy or light as it will on the sheet, or it's rather difficult to see what it will look like from further away as you look at the sheet.
When you zoom out the weight should show up a little heavier to a certain degree or at least be some what variable for the user. Similar to trace background color and opacity.
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
0 REPLIES 0
