Read more
Wishes
User Defined Ridges on Mesh for Grasshopper definition
Pato99
This is in reference to discussion posted here Rhino plug-in for mesh - limitation - Graphisoft Community about the limitations of the Grasshopper Mesh definition, where only Points can be used to create an AC Mesh.
We would like the option to create a Mesh from Curves or Polylines in survey data and have these represented on the AC Mesh. While a "Mesh from Curves" option would be useful, the definition would need to be able to merge both Points and Curves as part of the same mesh for accuracy and rogue survey marks such as Boundary Points.
Versions 10 to forced subscription
Metabox Prime-X P775DM2-G (Clevo),
GTX 1060 6GB GDDR5 VRAM - G-Sync,
i7-6700K (8M Cache up to 4.2 GHz),
32GB DDR4 2133MHZ,
512GB SATA 3 M.2 SSD,
Win 11 64
0 REPLIES 0
