Wishes
Using label for drawings on layout
ArchiMind
The label tool is powerful until we get to problems like labeling drawings‚ or other elements not included in the tool.
I believe that labels should be able to annotate everything, one potential use case would be labeling drawings in layout, showing all related information about the drawing (path, name, id ... )
For example, while working on the area schedule, I want to point out which schedule is used, because of the complexity of table itself I need to create it combination of lines and drawings.
I could make a workaround using a drawing title, but in this case, I lose control of the annotation visibility.
Stefan Veselinović
Versions 13 to 25
CPU: AMD Ryzen 9 5900X 12-Core
RAM:32GB
GPU: RTX 2080Ti
Windows 11
0 REPLIES 0
