Read more
Wishes
Visible folders in BIMcloud file navigation view
Would be nice to see both Folders and files when you select folder to find out what selected folder consist of. At the moment when you select folder it shows only files inside it - folders are invisible. I have "Show All Items" turned on. It is very unnatural that folders are not show in right navigation pane (green rectangle).
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v26 INT / NOR (5002)
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
2 REPLIES 2
4dProof
it might just be a perspective thing... I always think of it like the left column is organization and navigation, the right column is exclusively to select files to open/join. This also helps to semi-hide files by keeping them in the main "projects" directory, since you only see them if you select that directory. I use this to keep working files and my template less visible to people not part of the BIM team
Dear All,
Thank you for sharing your ideas and opinions regarding this request!
I'm glad to say that we took notice and we have added this Wish into our Wish database.
(For future reference, you can refer to it as IDEA-9219)
I hope we see this get implemented in the future.
Have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
