Read more
Wishes
WISH: Ability to Enrich Hotlink Module Information:
StefanV_BCP
The geometry of elements can remain static in the hotlink module, but the ability to override the inside property of the element in the host file is crucial to reduce cumbersome workflows. While the use of Master ID within the hotlink module can be helpful, it may not fully address the issue for users enriching their elements through properties. Empowering users to have greater control over element information within the hotlink module would lead to more streamlined processes and increased productivity.
One of the case where this process would benefit the most are zones. Especially when you work on big design like towers, where their geometry is the same but their naming convention change according to the design need
Stefan Veselinović
BIM Manager for Bureau Cube Partners, Serbia
WISH HUB: https://community.graphisoft.com/t5/Wishes/WISH-hub/td-p/393063
1 REPLY 1
Erwin Edel
A 'module override' button, similar to Model View Options override would be great for zones.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
