2024 Technology Preview Program
Wishes
Wall Profile to match Revit
MASz
I think it's important that Archicad has wall profile functionality to match Revit, seen here.
When importing IFC from Revit, it converts walls that use wall profiles to objects by default - which is highly problematic. Instead, it could keep them as walls and use a wall profile.
The functionality already exists within Archicad in the form of openings. It would just need to be repurposed for a new tool. Otherwise, you basically have to extend the wall and then cut out the intended profile with the opening.
A wall profile would also allow more flexibility in general, and is just more straightforward than trying to use openings or SEOs to achieve the same result.
AC27 AUS, Windows 11, i9-13900KF, RTX3090, 128GB DDR5, 4k144 display
0 REPLIES 0
