Read more
Wishes
Wall diplayed correctly in 2D based on 3D
Karel Landa
Hi everybody.
At the moment the Wall tool is able to correctly show its position in floorplan based on position of cutting plane and correctly show if it is cut/under the plane/above the plane. Also it works good if I want to show it in roof plan and the wall is in Ground floor based on visibility of floorplan to lower stories.
Problem is when there is SEO with roof/shell or any other element which is making the wall slanted. At that moment, the wall is still showing cut part in its whole length.
I would like if the Wall would have the same ability as other tools (beam, column, roof, shell) and correctly represent the 2D based on 2D model.
Also, the Wall tool could use some boost/upgrade similar to Beam/Columns in AC23.
Best regards
0 REPLIES 0
