Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Wishes
WallholeFraming.gsm ON/OF Manually
cagarruta
Dear Graphisoft developer,
Would it be possible for you to include a manual control to activate/discard the associated window structures in the lists schedule?
As you know these parameters are controlled with the Macro WallholeFraming.gsm at this line:
! Interactive Schedule and Listing related display options
if detalle=0 then
if GLOB_SCRIPT_TYPE = 2 | GLOB_SCRIPT_TYPE = 3 then
if GLOB_PREVIEW_MODE = 2 then ! IS but not surface
if not(bShowCasingOnLists) then bDrawOutsideTrim = 0
if not(bShowCasingOnLists) then bDrawInsideTrim = 0
if not(bShowSillOnLists) then bDrawSill = 0
if not(bShowSillOnLists) then bCutSillPlace = 0
if not(bShowBoardOnLists) then bDrawBoard = 0
bDrawThreshold = 0
bDrawShutter = 0
endif
endif
endif
I think it's easy for you and it would save us a lot of complications.
Thanks in advanced.
Archicad 25 SPA v6000
i9 9900K/32 Gb DDR4/1TB SSD/10GBPS Lan/Windows 10 PRO
1 REPLY 1
Benjamin Dani
Hello,
Thank you for sharing your idea with us!
I'm happy to say that I added this wish into our system as WISH-12583.
I hope it will get implemented in the near future!
Best regards,
Dani Benjamin
Technical Support Engineer
