2020-07-10 03:34 PM
just like in the "building materials" palette. Building material pallet shows inside(makes highlited) when i choose something before opening the palette. )thanks for reading.
2021-06-22 05:30 PM
2021-06-22 07:31 PM
LaszloNagy wrote:If the two Classification Systems share the same Property, then there is no issue. When we filter that Property it will have only one value. But if each Classification System has its own Visibility Property, then when I define the criteria, I will specify which Classification I am referring the the Visibility value that I want. So we will have Visibility_Class01 and Visibility_Class02. But in my opinion there would be no need to duplicate properties with the same name. And if I imported another Classification System that had a "Visibility" property and the project already has a property with the same name, then a popup message would alert and ask if the user want to duplicate it.
So, what happens if a Wall is using 2 Classification Systems, and based on one Classification, the Wall should be hidden, but based on the other it should be visible?
Does one Classification system take precedence over the other? Which one?
LaszloNagy wrote:Sorry Laszlo but I didn't understand. What do you mean by precedence?
What happens when in the case of Walls, the first Classification system needs to take precedence, but in the case of Slabs, the second Classification system needs to take precedence?
LaszloNagy wrote:This could be addressed by "Filter Combinations" and "Filter Rules"
Also, if you eliminate the system of Layers, you have to replace it with 4 Properties: Locked/Unlocked status, Visibility status, Intersection Priority Group, 3D display mode (Solid/wireframe).
2021-06-24 04:09 PM
2021-06-24 09:41 PM
jl_lt wrote:You mean assign
these properties would have to be assigned individually?
jl_lt wrote:I am not a Revit user. But from what I saw and understand, Revit has just a dumb Category Filter that you can define any intrinsic value. They are simple "Tags". Like: MEP, Architecture, Structure, Landscape, etc. Then you just filter elements that have that "Tag". The proposed Archicad Model Filter will use any data associated to an element to filter the model. Including Story, Height, Length, BM, Properties, etc. Way more powerful.
personally i never understood the concept of hiding a specific object like in revit.
jl_lt wrote:I don't think so. It would be more like a biker learning how to drive a bus. It is not rocket science.
from what i understand, eliminating layers would create a very sofisticated system with extreme flexibility, but also it would elevate complexity and potential for chaos for less experienced users;
2021-06-25 12:18 AM
Braza wrote:Now this is forward thinking! for a brief moment i imagined a Tony Stark-Jarvis design interaction, but instead of Ironman it would be a low budget school
Imagine: "Alexa"... "Show me only MEP ventilation duct elements that are scheduled to be applied today by the Contractor X"... Bam!
Now imagine how could poor Alexa do this with Layers.
2021-06-25 10:53 AM
jl_lt wrote:Exactly. And also the foundation for AC new features.
but this system would allow for much more complex interaction and data management right?
jl_lt wrote:I think it would be the same with Layers. They would be right there in "Filter Combinations". The only missing would be "Visibility" (The eye icon), as it would be intrinsically the "Rule" itself (If it is not in the criteria then it is not visible).
My gripe would be what Mr. Nagy points out: basic visibility properties currently handled by layer configuration would have to be handled separately
2021-07-22 11:48 AM
aryastark wrote:Alt+click on element do this. It works even on not selected elements.
to op Discussion click here:https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=70172#p313012 n ö
I never understood why archicad doesn't have this feature. Very surprising. Even relatively simple programs such as photoshop have the layer display feature of the selected element, while the absence of this in a complex program like archicad is a big handicap.
In a nutshell: through hundreds of layers, for the purposes of -changing layer name; changing it's priority level; duplicate it as a sequel to a close name for a reason; delete it etc.- layer palette should show [must make highlighted] automatically the selected elements layer when it opens.
valar morghulis.
