2024 Technology Preview Program
Wishes
Window sill information
agroni
In the window marker there is the possibility to show three different parameters. The “Sturzunterkante” can be referenced to the project origin. Why not also the “Rohparapethöhe”???
These are two different parameters but belong to the same groupe and which the construction company will build based on that. That means, the information about the opening of the window should have the same logic…in this case the heights referenced to project origin.
If you use “Wandbasis” (base of the wall) it gets even more confusing, because then everything on the floor plan must be referenced to the wall base like doors, beams, etc. Again, same logic!
The reference to the current floor "Aktuelle Geschoss" you can forget, especially when you work with split levels where the floors are in different heights.
A simple but necessary information
The BIMster @ AllesWirdGut
Currently: Archicad 26
User since Archicad 6.5 (2001)
0 REPLIES 0
