Read more
Wishes
Windows with top wall/plaster clousure in section
Mario Sacco
I'd like to see the plaster and the walls turn also in the sections, not only in plan.
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
16 REPLIES 16
You are not the only one.
I just tested this again, as it is something asked for a lot ... and the help file here:
http://help.graphisoft.com/ac16_help_INT/Files/wwhelp/wwhimpl/common/html/wwhelp.htm#href=Appendix_T...
even claims that we already have this feature! From that link:
The effect of your Turn Plaster settings will be displayed in Section/Elevation views as well. (To see the effect of these settings in the 3D window, you must set an additional option.)
If I check the closure box for "Show in 3D", then the mass around the window increases in proportion to the finish skin in Section... but the skin line does not turn - it just extends.
If the Help file is correct, then GS thinks they've already implemented this... and it is a bug. Otherwise, it's a wish and the Help file is where the bug lies. 😉
PS In testing this, I see a bad bug in the US window/door library if Cavity Closure is enabled and exterior trim is disabled... the exterior skin is cut back by an amount equal to the width of the exterior trim, were it to be enabled.
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.7, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Gabor Almasi
Thanks that you mentioned this case, we forwarded this issue to our design team to consider development on this area.
Gabor Almasi
Senior Product Manager
GRAPHISOFT
david_lozej
I prepare gdl library for Slovene window manufacturer "M Sora". This windows will include also closure in 3d.
I can announce that in one month they will be on the BIMComponents.
david_lozej
Some screenshots from "M Sora" library.
Well, it's been 5 years already since the last post here and as I am still running on AC18, I am very curious if GRAPHISOFT fixed this issue in AC22. Do wall/plaster closures show in the sections generated by AC22 now?...
Lingwisyer
Guru
Unless I have been doing something wrong, it has not been implemented...
Ling.
Erwin Edel
The floorplan display is just cosmetic too. No actual Building Material involved (for quantity take off).
I suppose the wait is for GDL to catch up to the Building Material work method, which has been around since ArchiCAD17
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
If that's of any comfort, wall/plaster closures do not show up in Revit sections, either
