Read more
Wishes
Wish: Custom Complex Profiles for Door/Window Jambs
Red
I know it isn't as easy as what I am saying/typing, but I would like to start the conversation on it at least. If possible, it would be incredible if doors/windows had custom profile frames (header, sills and jambs) similar to other parts in the ArchiCAD. AC sections have definitely come along way with the evolutions of complex profiles and this, in my opinion, would be another huge step for saving time in detailing.
Hopefully I explain what I am thinking here....
Possibly still have the level of detail for 2d and/or elevation options... Similar to complex profiles now, it could have a "Massing" option similar to "Opening Reference" so that a polyline rectangle would determine width/height of the simple level.
Thoughts?!?
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
12 REPLIES 12
I agree, this would be both useful and desirable.
(I have created a Poll for this Wish. Unfortunately, in the new forum Polls are not created automatically, they need to be created manually when posting.)
It is possible now but it would be an awful lot of work to make the current doors and windows compatible.
In fact the detail has always been possible - just not with using custom complex profiles.
GDL object now have the ability to use complex profiles so it would be possible to script door and window frames to use these profiles.
The object can also be scale sensitive so at a low scale the profile could be a simple box instead of the actual profile and only when larger than a particular scale would you see the true profile.
As I say it would be a lot of work - especially setting the objects up to mitre the different profiles at the corners.
At the moment most frames would simply be a PRISM_ with holes cut in it for glass or sashes.
Red
Thanks for the input, this was the project that got mind mind churning on the idea. I use complex profiles like a mad man and I had to turn the windows off in the MVO to achieve the look I was after.
Thanks,
Red
i7 8700k
64gb RAM
Erwin Edel
As a workaround, you could place empty opening and fill them with the curtain wall tool. You can define custom profiles for this. Allthough the curtain wall tool itself is not without problems either.
During the recession we were asked to do some 3D rendered principal details for a manufacturer of prefab dormer windows. I was working with the typical UPVC window frames you'd see there and indeed getting the joints to clean up / mitre was a pain in the behind.
For the section you show I'd probably patch over with 2D object too. In metric land I'd say it is a 1:20 scale section. Typically we do not go beyond 1:50, which pretty much makes things smalle than 5-10 mm hard to notice after you factor in pen weight. 1:5 details in 2D take care of the rest.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
snow
I don't know what's exactly going on with the reworking of doors an windows at the moment...
... but I often thought in last time which big advantage it would be to have complex profiles available for doors and windows... maybe the subject is already part of the current development... 😏
... the too simple symbols especially for windows could be replaced if the the elements in section are real projected.
And yes, of course the level of detail has to be controllable.
The new opening-element-tool could be a something like a fusion of
  • opening-elements tool
  • complex profile editor
  • library part maker
Let me add to have some kind of library with conmen windows- and door profiles, maybe localised  would be very nice and also the ability to bring window-sill ends to the elements...
... and just determine freely if the element is door or window.
ARCHICAD for Future
archicad versions 8-27 | mac os 13 | win 10
Lingwisyer
Guru
Hmooslechner has recently shown off his development of his own door object that can do this.
https://community.graphisoft.com/t5/Developer-forum/Door-with-Profilemanager/td-p/319666
Glad to see this is still a topic and that someone has been working on a part. IMO, this is a no-brainer that Complex Profiles needs to be incorporated with openings. It would significantly streamline the detailing phase of the project.
Thanks,
Red
i7 8700k
64gb RAM
I used the curtain wall method on my current project. It is a helpful method while we wait, LOL
Thanks,
Red
i7 8700k
64gb RAM
Jim Allen
Does someone want to add this to the Community wishlist Google Sheet I've created to coordinate all these ideas?
https://docs.google.com/spreadsheets/d/1doTzgjqEsRr50sxszCNXrTLC17SvaemHxo_zfCFR6GE/edit?usp=sharing
The thread dealing with these is here:
https://community.graphisoft.com/t5/Wishes-forum/Archicad-Future-27-Poll/m-p/362707#M21703
I would add this myself if I thought I could concisely summarise all the benefits and functionality.
Archicad 27 UKI | OS X 12.7.1 Monterey
