2023-09-28
10:32 AM
- last edited on
2023-09-29
01:02 AM
by
Please ad an option in 3D styles for a sketch line.
It would be greatly appreciated if there could be an option in the '3D Styles' menu to choose a sketch line. This way, you can add a sketch style to the 3D view without sacrificing mobility, just as easily as SketchUp has implemented it. This allows you to retain the functionality of your view and efficiently incorporate a 'sketch' effect.
2023-09-28 06:33 PM
You can use sketch render feature as Archicad doesn't have a sketch style at this moment.
2023-09-29 09:00 AM
Dear Mahmoud Qenawi,
Thank you for your advice. It's great to see people willing to share their thoughts. I was indeed aware of the render function you described, and I am currently using it to achieve the sketch-like appearance.
However, what I find less suitable about this feature is that it produces a "disconnected" image that needs to be re-rendered each time. If this functionality were to be integrated into the 3D styles, possibly with the option to select your own lines, it would create a dynamic link that updates automatically with any changes. This would save me a significant amount of time, which is why I submitted my feature request.
Once again, thank you for your input!
2023-09-29 07:47 PM
It would be a nice feature in BIMx too. It helps to keep the nostalgic architect in play. It makes me feel good to see it in Sketchup. It would be a fun option in the Archicad 3D LIVE window and not just a static render.👍
2023-09-29 10:05 PM
Interesting that Graphic Overrides can apply a line colour in 3D but not a linetype. Perhaps a solution would be to have GO's linetype overrides work in the 3D window.
