2024 Technology Preview Program
Wishes
Wishlist - Ability to Show Headlines in Schedules Without Contributing to Column Widths
Josh Verran
In Schedules, I would like the ability to Show Headline without that field contributing to the column width(s).
For example, I have two columns in my schedule, one is 30mm wide, the other is 50mm wide.
If I then add a new field/column, and set that field to Show as Headline, even thou the field presents as a Row, there is now a column which has a minimum width of 2mm and shows as a funny group of text at the top.
My original two columns are nudged over (like a margin), due to the headline.
This image might demonstrate clearer.
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER | LinkedIn | My Top Wishes
ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Perth, Australia and Tauranga, New Zealand
Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
1 REPLY 1
Karel Landa
 Hi Josh,
this one is going to be in new version of Archicad (27). If you watch the video showcasing the new functions, you can see it at this time.
Best regards
Karel
