Wishes
Zone Criterion for Find & Select
The ability to find elements by what zone they are in. I know, draw a marquee around the room. Still.
James Murray
Archicad 25 • Rill Architects • macOS • OnLand.info
2 REPLIES 2
Or by what type of zone. The Marquee won't help you there.
Good idea.
Until F&S has this, the Interactive Schedule lets you do it (depending on your requirements) ... generate an appropriately filtered and sorted schedule preview, select the desired elements, and click the Select button. No substitute for your wish in efficiency since the IS Preview window is modal and has to be closed to do anything to the selected elements, change floors, etc...and doesn't select in 3D. Your wish is the right solution IMHO.
Karl
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Learn and get certified!
