2024 Technology Preview Program
Wishes
add plan display parameters in the selection criteria
abdelaziz
Hi
Would it be possible to add the parameters of display in plan in the criterion of selection of the filter of selection and in the GO, sela will allow us to control the mode of display of the walls, For example if I have a window that is placed on a wall that is offset upwards from level 0 and that wall is displayed on the floor only but the display mode is projection then the window in the table will be placed on level 1, having a way to select the display mode of the walls would help us to solve this problem more easily
AMD Ryzen 5950x
AMD RX 6750xt
AC27
0 REPLIES 0
