Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Wishes
consolidation of moprhs
alemanda
It would be very useful to have a tool that allows to consolidate a morph reducing triangulation, consolidatin all the faces on the same plane into one morph.
Very useful when importing not optimized 3ds objects and parts directly from the manufacturer website.
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
3 REPLIES 3
I would agree.
The reduce segmentation work OK for non-co-planar surfaces but does nothing for co-planar at all.
I was thinking this could be solved by Find & Selecting Morph Edges. I drew a Marquee then used the "Element Type IS Morph Edge" + "Marquee IS Inside Partially" F&S criteria, but it either selects all Morph Edges or none, both in 2D and 3D. It doesn't matter which Marquee method I use in 3D either.
Actually, I checked this in AC16 where the Morph Tool appeared and it didn't work even then. So this selection method doesn't work, which could be an answer to this wish. I will report it to Graphisoft along with the wish.
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Katalin Borszeki
Hi all,
We added a wish to improve the functionality of the Select Morp Edge/Face criteria of the Find&Select so only the eges/faces in the area of the marquee are selected not the whole Morph with all of its edges. Tx for the report.
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
