Read more
Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
editable hotspots in gdl-scripts - EASIER!
Hmooslechner
My wish:
make easier usable and understandable commands for editable hotspots!
till now it is nescessary to write like this for one single hotsot to drag:
!! somwhere above:
 unID = 1
!! and later:
HOTSPOT2 0,             0,   unID, EVEKTOR, 1+128 :unID=unID+1   !BASE
HOTSPOT2 EVEKTOR, 0,   unID, EVEKTOR, 2         :unID=unID+1   !MOVE
HOTSPOT2 -1,            0,   unID, EVEKTOR, 3         :unID=unID+1   !REF
very much code for one single needet action!
What is wandering in my mind:
e_hotspot2(3) variablename (x, y, (z), direction(x, y or z), appearingColour, code for different symboltypes)
the counting of the hotspot - id should be made by Archicad within itself without any user-needet command!
so - after the varaible-name it should be possible to point the exact place of the hotspots origin without the need of transform the coordinate-system with add2 or similar within the commandline like above.
then the direction + or - should be declared only by typing x, y, or z.
New: the appearing colour of the hotspot should be editable here as next.
Then - also complete new : some types of diffrent hotspot-symbols should be bossible to be declared - simple shapes licke circle, squares, or maybe real icons to choose for it.
Then - after this - it should be possible for the normal user: If the mouse-curser is hovering above such a point - the variablename should be readable before any click on it!
Next: till now it is only possible to change vectors with this kind of hotspots.
But lets get some steps further!
If a user points on any text displayd by a GDL - it should be etitable direct in the drawing enviroment without the need for opening any dialogue-box.
if a user points on any surface - it also should be editable direct without opening the dialogue!
If something is changed this way it should change the exact variable used in GDL like you edited it in th normal user dialogue.
So it would be much easier for normal users to wirk with GDL-Parts!
5 REPLIES 5
alemanda
Yes! This would be a big big big enhancement!
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
RandyC
agreed as a GDL beginner the 3d hotspot is extremely confusion in its present form
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
RandyC wrote:
agreed as a GDL beginner the the best pre workout supplements simply work but it's extremely confusion in its present form
I haven't used GDL in ages mostly because I couldn't get the hang of it because of stuff like the 3d hotspots. Have the made hotspots simpler in the latest GDL recently?
Agreed. That would be a great improvement, especially when trying to manage multiple editable hotspots!
Well, honestly once you learn it it is clear why it has so many parameters.
I don't think you can make it much more simple without cutting function.
