Hi! So our problem is, we want different displays for an element in each story level. For example, for a beam, in the floor plan and section category, you have the option to choose show on stories. Fine until now. Then in the category, of floor plan display, you should have had the opportunity to choose how to see it on each floor. For example, you may want on the ground floor solid line and for the second floor hidden line.
Please Archicad make that possible, it will really solve a big problem!
