2024 Technology Preview Program
Wishes
the multiselection option set property in formulas
abdelaziz
in the case where we use an option set property with multiselection, it would be very useful to be able to recover this property in the formulas to allow us to reduce the number of properties,
example of use for this function in formula
1- Property of multiselection option set for finishes, for example:
W01<wall finish code>_ type of wall finish_ description of wall finish C01<ceiling finish code>_ type of ceiling finish_ description of ceiling finish F01 < floor finish>_ floor finish type_ floor finish description
2- for the wall finish for example there are 3 formulas
    2-1 formula that retrieves the wall finish code
    2-2 formula that retrieves the wall finish type
    2-2 formula that retrieves the wall finish description
this method works with standard option sets, in this way the content of the properties (formula) is managed from a single property provided that the separation rule is respected, the problem is that I have to create 3 properties set of finish option to manage 9 properties (formula), with the introduction of multi-selection option sets, I would be able to input my wall, floor and ceiling finishes information into 1 property to manage 9 properties (formula)
AMD Ryzen 5950x
AMD RX 6750xt
AC27
0 REPLIES 0
