There is a problem with the Italian version of ArchiCAD and its template for the material aluminum, translated as "aluminio". But "aluminio" doesn't belong to the Italian language. The correct word is "alluminio" with two "l".
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0/200 Votes
