Finish/treads of the stairs to not show when selecting "without finishes".
Leire Bilbao
When doing a concrete structural section for example, if you click the option "without finishes" the floors and plasters and other layers hide, but the tread finishes on your stair stay. It should be consistent and behave as a floor finish.
Currently I need to do 2 stairs, one for the concrete and one for the finish, or draw / cover with fills which is bad
3 Comments
tkrepler_fjc
I think it is a pretty important missing feature. We need the stair structure (concrete, steel, etc.) to show in certain views without the stair finish parts.
Karel Landa
Still can't believe this is not implemented already.
Stairs are "just" a bunch of GDL objects merged into one tool.
Before this get the attention, you can duplicate the riser and thread objects from library and add this do the 3D description:
IF GLOB_STRUCTURE_DISPLAY <> 0 THEN
END
ENDIF
this way, at least in 3D based views finishes will disappear. Not in 2D though.
tkrepler_fjc
Hi Karel, well, unfortunately, we all need both. So we go with the 2 stairs solution.
Status
Open
with 17/200 Votes 11.764705882353%
Wish details
