Hi all,
When you change the Home Storey of a wall, the doors and windows associated with it should adjust their Anchor too if set to a reference a Storey.
eg. You have a wall linked GF-FF with a door / window in it anchored to GF. Changing the Home Storey of the wall to FF-SF, the door / window remains anchored to GF and hence is now floating in space. Unintuitive. If you so happen to have duplicated an existing wall before changing the Home Storey, you now have identical overlapping doors / windows which you might not even notice.
The current Workaround it to copy / cut and paste the wall in the Floorplan.
Ling.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0/200 Votes
