Schedules - Dimensioning and calculation units
VictorStefanarh
Hi all,
I would like to request an improvement regarding the way measurement units are assigned and controlled in Schedules in Archicad. At the moment, Schedules are entirely dependent on the global project settings, namely Dimensions and Calculation Units defined in Project Preferences. While Dimension Units can be partially controlled through View Settings, Calculation Units cannot, which creates a major limitation in real quantity take-off workflows.
Because of this restriction, in many practical situations we are forced to keep certain schedules on Manual Update, and every time a schedule needs to be refreshed—which happens very frequently during design development—we must first go into Calculation Units in Project Preferences, change the unit system there, and only then update the schedule. This process is repetitive, inefficient, and very prone to human error, especially in larger projects with multiple schedules requiring different unit systems.
At the very least, it should be possible to define the measurement units independently per Schedule. If unit control per individual element or field inside a schedule is not technically feasible at this moment, then a minimum solution would be to introduce a Calculation Units override inside View Settings, similar to how Dimension Units are handled. This would allow each schedule view to operate with its own unit system, without forcing destructive changes at the global project level.
Thank you,
Victor
Status
Submitted
with 12 Votes
