2 weeks ago - last edited a week ago by Karl Ottenstein
We know that taking part in an experiment can be challenging from time to time. Do you have issues with installing or running the Archicad AI Visualizer Add-on? This is your place to ask your questions and initiate discussion with others about technical difficulties you may experience while trying to install or run the experimental add-on, or generate images.
2 weeks ago
- last edited
2 weeks ago
Hello, I have issues launching the Ai Engine. The window shows me some errors and fails to launch.
Hopefully someone can provide me with some answers.
Kind regards!
Paul Spaltman
2 weeks ago
2 weeks ago
Thanks, it worked!
2 weeks ago
Can you please tell, where the sd_webui is located on your computer?
Kind regards,
Illés
2 weeks ago
I’ve tried installing the AI visualiser and just get an error in Terminal when I run the first command saying the process cannot proceed because of various errors.
2 weeks ago - last edited 2 weeks ago
ERROR: python3-venv is not installed, aborting
After dragging run.sh it to the Terminal window and hit Enter, this message shows up in HomeBrew / Terminal.
I have moved the AI Visualizer folder from Add-ons into Archicad 27 folder > Add-ons > Extra.
And i have moved the sd.webui folder into Archicad 27 folder.
2 weeks ago
I've downloaded a nearly 20GB compressed package, but I'm struggling to extract it. I've tried several pieces of software like 7-zip, etc., and each time it reports dozens of errors. Has anyone experienced a similar issue? I'm using Windows 11.
2 weeks ago
I unzipped it with WinRar without any issues. But it's a ton of data, so it's tricky. Good luck!
2 weeks ago
You should extract the AI visualizer to the AC27 folder and sd.webui to C:
