Archicad C++ API
AC25 API Compile Error - ParameterPackTraits.hpp
Erenford
I'm trying to compile one of the examples of the API (Element_Test) and I'm encountering errors on GSRoot\ParameterPackTraits.hpp.
Rebuild started...
1>------ Rebuild All started: Project: Element_Test, Configuration: Debug x64 ------
1>Compiling the localized GRC file...
1>Compiling the non-localized GRC file...
1>Compiling the RC2 file...
1>Microsoft (R) Windows (R) Resource Compiler Version 10.0.10011.16384
1>
1>Copyright (C) Microsoft Corporation.  All rights reserved.
1>
1>
1>APICommon.c
1>C:\Software Development\Addon Development\API Development Kit 25.3002\Support\Modules\GSRoot\ParameterPackTraits.hpp(80,23): error C2220: the following warning is treated as an error
1>C:\Software Development\Addon Development\API Development Kit 25.3002\Support\Modules\GSRoot\ParameterPackTraits.hpp(80,23): warning C4499: 'static': an explicit specialization cannot have a storage class (ignored)
1>C:\Software Development\Addon Development\API Development Kit 25.3002\Support\Modules\GSRoot\ParameterPackTraits.hpp(92,23): warning C4499: 'static': an explicit specialization cannot have a storage class (ignored)
1>PropertyUtils.cpp
1>Element_Test.cpp
1>Element_Trim.cpp
1>Element_Tools.cpp
1>Element_Tips.cpp
1>Element_SolidLink.cpp
1>Element_Snippets.cpp
1>Element_Set.cpp
1>Element_Modify.cpp
1>Element_Hotlink.cpp
1>Element_Edit.cpp
1>Element_Basics.cpp
1>Element_Batch_Create.cpp
1>Dumper.cpp
1>APISpeedTest.cpp
1>Generating Code...
1>Done building project "Element_Test.vcxproj" -- FAILED.
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
Only thing I did is edit the MDID (dev+addon id).
I've tried other examples (Attribute_Test), same thing happened
Any ideas on how to fix this?
Archicad 25 5010 INT FULL
Archicad 26 5002 INT FULL
Visual Studio Professional 2019
Win 10 Pro 64-bit
4 REPLIES 4
akomporday
Hi Erenford,
It is a known issue, the fix is already under development. Until then, you can work around it by setting the compiler warning level from level 4 (/W4) to level 3 (/W3). It should compile after that.
Regards,
Andras
Viktor Kovacs
This is happening because you are trying to compile the code with a later version of Visual Studio than what Archicad builds with.
You can work around the situation by lowering the "Warning Level", and turn off "Treat Warnings As Errors" in the project settings.
Erenford
Thanks it compiles now. Seems lowering the "Warning Level" is enough.
Win 10 Pro 64-bit
Dismiss
Also just hit the same thing in vs2019 (in the year 2022). Note that trying to use vs2017 seemed to hit a pragma that only the 2019 build tools are supported. So curious.
