Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Archicad C++ API
Disabling and enabling the 3d view of an object
Vladislav V
Hello, can you tell me which command to use in the GDL script so that the 3d view can be disabled and enabled?
Mahmoud Qenawi
You mean this:
AC 27 INT 4001 - AC 26 INT 5002 ( For MEP Purposes )
David Maudlin
Vladislav V:
One way is to set up a parameter for not showing 3D (my example uses an option from a Values list), then in the 3D Script adding a line of code such as:
If Show_3D="None" Then END ! no model
You should add a Signature to your Profile (click the Profile button near the top of this page) with your Archicad version and operating system (see mine for an example) for more accurate help in this forum.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
